having an issue???????????
nitin_saini
i want to use ruckus AP model ZF7321 dual band AP as a wireless router without zone director and any i want to used it for DHCP server or ADSL modem as a router is it possible or not
2 REPLIES 2
Esteemed Contributor II
Yes, you can use zf7321 standalone firmware 100.1.0.0.432 to configure your AP as a Wireless router.
However, with only one Ethernet interface, which must be your WAN to the DSL modem, you will only
be able to connect to an Internal WLAN from wireless devices.  You still need to define a Local Network,
and use NAT Route to WAN under your WLAN definition.
APs with two or more Ethernet ports, can connect a second one to a switch to allow LAN (wired) as well
as Wireless access.
https://support.ruckuswireless.com/software/838-standalone-ap-software-100-1-0-0-432-indoor-aps
nitin_saini
i want only wireless access
