I am trying to do the migration from an ZD1200 to vSN-e. Therefore I have now two R510 in a test-enviroment connected to an brandnew installed vSN-e (I do not use the automatically migrating-service by vSN-e!!).
I do have the problem, that the two R510 do not activate the WLAN-RADIO.
I have successfully migrated firmware of the APs from ZD-firmware to now SCG-firmware, and set the command
for the two test-APs. On the vSN-e, I do have set up an new WLAN, the APs are connected successfully to the vSN-e, but both APs dont activate the RADIO (nether 2GHz nor 5 GHz) and therefore I dont get an SSID-signal.
In the configuration, it says just !! I do have a NoiseFloor from -70 on 2,4 GHz and -102 on 5 GHz / Tx Power ist
Does anybody has a clue, what to do?
Is this a configuration-mistake? As the old ZD1200 I do have looked thru the whole vSN-e configuration but I dont see a real mistake?
best regards
Christian
