not working SCI v5.1.1 after a setting which dhcp ip to static ip
hyosang_choi
Valued Contributor
Hi.
I tried to deploy latest SCI v5.1.1 for DEMO.
I notice that after I completed initial seup complete with dhcp ip, if I re-configured dhcp ip to static ip, I can't see properly login page.
In this problem, SCI show me "500 Internal Server Error".
Is it a intended or a bug?
If it's a intended work, should he fresh-install again when he installed SCI with dhcp ip by mistake?
Regards.
8 REPLIES 8
Hello
I have had a same case.
So I reinstalled SCI.
By the way, How can i back up DB of SCI
and how can I restore db on new SCI sever.
Do you have a procedure document?
For backup, I would strongly recommend taking a VM snapshot. That would be the easiest and avoid all the complexities of restoring data in a new server.
Thanks!
Could Ruckus provide backup method at futher release?
You will need a backup and restore method for the migration when you go someday.
Our recommendation is to take a VM snapshot. That is still the surest and easiest way to do a backup and restore.
