07-27-2023 06:33 AM
I read RUCKUS blog on hospitality and I want to make PMS PSK like it says on blog with RWG. Which PMS work? How to do this? Is there video?
07-28-2023 12:30 PM
I highly recommend you watch the entire video linked above, but if you just want to jump to see a peek at the PMS integration aspect, you can skip ahead using: https://youtu.be/t-GAYqGCRNo?t=833
But you will need to have completed all of the steps prior to this section to make it work.
07-27-2023 06:35 AM
This is the blog post from ruckus, how do I do this? https://www.ruckusnetworks.com/blog/2023/the-challenges-of-delivering-awesome-hospitality-wi-fi/ Is there video?
07-28-2023 12:05 PM
The RWG has PMS integrations available from a pull down menu that include the following options:
You can learn more about DPSK in this YouTube video guide: https://www.youtube.com/watch?v=t-GAYqGCRNo&list=PLySwoo7u9-KIxn3bHPTzmOWm2OmfF9VIZ&index=10
07-28-2023 12:30 PM
07-28-2023 12:50 PM
The PMS integrations that are supported by RWG are the following: Agilysis LMS, Clarity, Comtrol UHLL, Galaxy 2-Way HSIA, Hilton OnQ, Hotel Key, Infor, Infor REST, InnQuest, Innsist, MICROS FIAS, MICROS HTNG, Marriott, Mews, RG Nets, Resco and SMS Host MSIP. RWG comes with a PMS simulator and a sample guest repository using the MICROS FIAS standard. You can find instructions to setup the PMS simulator using DPSK mangling on this doc at the RUCKUS support portal: https://support.ruckuswireless.com/documents/4408-ruckus-wan-gateway-dpsk-step-by-step-configuration
