โ02-17-2025 03:24 PM
โ02-18-2025 05:46 AM
Hi @JT ,
As per the case description, I understand that your Ruckus setup is not working and are facing intermittent connection issues .
1) Was there any power outage since you started facing the issue?
2) On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
โ02-20-2025 06:35 AM
Hello @JT ,
โ02-24-2025 09:59 AM
Hello @JT ,
โ02-26-2025 07:01 AM
Hi @JT ,
Thank you.
