Announcement: RUCKUS IoT 2.1.0.0 Product Guides Published on RUCKUS Support Portal
jenniferbush
Contributor
As requested, the RUCKUS IoT 2.1.0.0 Product Guides have been published on the RUCKUS Support Portal.  The PM can share the links below as needed for release announcements.
RUCKUS IoT 2.1.0.0 (GA) Controller Release Notes
https://support.ruckuswireless.com/documents/4591
RUCKUS IoT 2.1.0.0 (GA) Controller Configuration Guide
https://support.ruckuswireless.com/documents/4592
RUCKUS IoT 2.1.0.0 (GA) Controller Installation Guide
https://support.ruckuswireless.com/documents/4593
RUCKUS IoT 2.1.0.0 (GA) Controller SDK Programming Guide
https://support.ruckuswireless.com/documents/4594
RUCKUS IoT 2.1.0.0 (GA) Controller Software Licensing Guide
https://support.ruckuswireless.com/documents/4595
Note: HTML versions of the product guides are available on the Technical Content Portal  (https://docs.commscope.com) and included as embedded links on the RUCKUS Support Portal.
0 REPLIES 0
Labels
