I was planning to practice and explore smartzone so I am trying to install it in my VMWare workstation but the problem is I follow the guides and put the management IP but when I access it through my client's browser I always get the "502 Bad Gateway" error does any here have any answer to this problem? Or any other way to explore and practice smartzone. I am only running a laptop with 8gb RAM. We have a physical ICX switch and Ruckus AP which I will also try to add to the configured smartzone if possible. Will attach screenshots of the error and the specs/configuration of each VM:
Windows 10 Client:
ERROR
WINDOWS CLIENT SPECS/NETWORK CONFIG
SMARTZONE 300 Virtual Config:
SMARTZONE 300 - Specs
Note: They can ping each other. The only problem is the bad gateway error.
I hope someone can help me here.
Kind Regards,
Jam
