Ruckus ICX 7150
alexandr_potkin
Hello everyone!
Need help. Some strange with my ICX7150. When I try firmware 09.0 get error with RADIUS TLS. When switch are boots see in log:
cp: can't stat '/.pkg/libpam/etc/*': No such file or directory
Creating TUN device
Creating the first Tap interface
ERROR: Failure in gw add
Starting TPM Infra
Group tss and User tss created
hostname set to Ruckus-ICX
Starting TCSD Daemon in 'fi' namespace
TCSD Up and Running
Enabling time stamp.
Setting Unix datagram queue len.
 Setting TCP keep alive params
Moving app to flash....
could not read config file /etc/radsecproxy.conf
So can't log in by RADIUS...
15 REPLIES 15
@jain_jose Its taking too much time to boot casue of this errors.. is thre a fix for the 90.a Firmware ?
xander
Was this issue of your resolved?
yoexy
Somebody knows about this, I'm getting the same
nbctcp
I am getting the same error using this SPR09010cufi.bin
I am using this command to upgrade
# copy tftp flash ipaddress SPR09010cufi.bin secondary
do I need to upgrade using manifest
show me proper firmware upgrade
UPDATE1:
1. upgrading 8.0.90 to 8.0.95 to 9.0.10c causing same error as OP have
2. now when I press Enter, it produce ^M. putty or TeraTerm same result
3. can't ssh but can ping and access webgui
4. WebCLI always give wrong password. I try different admin a/c or super, same error
Anyone encounter same issue after upgrading to 9.0.10c?
The radsec (new in 9010b) error is not an issue by itself and bootup times are longer in 9.x than 8.x. See the following note:
Please open a support case (see my signature) if additional assistance is needed on this item.
