ICX 08.0.30t System Started bug
NTP is syncing properly, and the time is correct, but 08.0.30t does not calculate the system started time properly.  This adversely reports the wrong information to tools like Solar Winds, too.
SSH@Building_15_Stack#sh ver
  Copyright (c) 1996-2016 Brocade Communications Systems, Inc. All rights reserved.
    UNIT 1: compiled on Feb 13 2019 at 17:44:50 labeled as ICX64S08030t
(8559704 bytes) from Primary ICX64S08030t.bin
        SW: Version 08.0.30tT311
    UNIT 2: compiled on Feb 13 2019 at 17:44:50 labeled as ICX64S08030t
  Boot-Monitor Image size = 786944, Version:10.1.05T310 (kxz10105)
  HW: Stackable ICX6430-24-HPOE
UNIT 1: SL 1: ICX6430-24P POE 24-port Management Module
  Serial  #: Redacted
  License: BASE_SOFT_PACKAGE   (LID: Redacted)
  P-ENGINE  0: type E7FE, rev 01
UNIT 1: SL 2: ICX6430-SFP 4port 4G Module
UNIT 2: SL 1: ICX6430-48P POE 48-port Management Module
  Serial  #: Redacted
  P-ENGINE  0: type DF70, rev 01
  P-ENGINE  1: type DF70, rev 01
UNIT 2: SL 2: ICX6430-SFP 4port 4G Module
  500 MHz ARM processor ARMv5TE, 400 MHz bus
32768 KB flash memory
  256 MB DRAM
STACKID 1  system uptime is 12 hour(s) 44 minute(s) 49 second(s)
STACKID 2  system uptime is 12 hour(s) 44 minute(s) 49 second(s)
The system started at 19:00:21 Eastern Wed Dec 31 1969
SSH@StatePark#sh ver
    UNIT 1: compiled on Feb 13 2019 at 18:30:50 labeled as FCXR08030t
(10545807 bytes) from Secondary FCXR08030t.bin
        SW: Version 08.0.30tT7f3
  Boot-Monitor Image size = 370695, Version:10.1.00T7f5 (grz10100)
  HW: Stackable ICX6610-24F
UNIT 1: SL 1: ICX6610-24F 24-port Management Module
  Serial  #: Redacted
  License: ICX6610_BASE_ROUTER_SOFT_PACKAGE   (LID: Redacted)
  P-ENGINE  0: type E02B, rev 01
UNIT 1: SL 2: ICX6610-QSFP 10-port 160G Module
UNIT 1: SL 3: ICX6610-8-port Dual Mode(SFP/SFP+) Module
  800 MHz Power PC processor 8544E (version 0021/0023) 400 MHz bus
65536 KB flash memory
  512 MB DRAM
STACKID 1  system uptime is 14 hour(s) 16 minute(s) 20 second(s)
The system started at 01:28:07 Eastern Thu Feb 07 2036
 The system : started=warm start reloaded=by "reload"
9 REPLIES 9
BenBeck
I'd recommend opening a support case for this one.
Esteemed Contributor II
Can you please open a ticket with Tech-Support so this issue can be filed as a bug?
https://support.ruckuswireless.com/cases/new
Thank you.  I opened case 00910840.  I do not actually expect any technical support with it; since, the time is properly reported.  I already rolled it back.  Here is a demo that the NTP was working properly...
SSH@Building_17#sh ver
  Serial  #: Redacted
  256 MB DRAM
STACKID 1  system uptime is 12 hour(s) 39 minute(s) 50 second(s)
The system started at 19:00:22 Eastern Wed Dec 31 1969
SSH@Building_17#sh clock
09:31:12.077 Eastern Fri Mar 22 2019
SSH@Building_17#sh ntp associations
   address         ref clock      st  when  poll reach  delay   offset  disp
*~10.220.1.1      129.6.15.28      2    16    64   377  2.002   0.3398  4.667
* synced, # selected, + candidate, - outlayer, x falseticker, ~ configured
SSH@Building_17#sh ntp stat
 Clock is synchronized, stratum 3, reference clock is 10.220.1.1
 precision is 2**-16
 reference time is 3762528062.2064802582 (09:31:14.2064802582 Eastern Fri Mar 22 2019)
 clock offset is 0.3398 msec, root delay is 23.8860 msec
 root dispersion is 11.2220 msec,  peer dispersion is 5.0081 msec
 system poll interval is 64,  last clock update was 281 sec ago
 NTP server mode is enabled, NTP client mode is enabled
 NTP master mode is disabled, NTP master stratum is 8
 NTP is not in panic mode
