Ssh is not accepting username and password
israr_ahmed_93c
i have configured crypto key ,username and password. when we are trying to ssh its asking username and password but when we are typing username and password its showing "Using keyboard-interactive authentication." error. we enable telnet because ssh is not working but unfortunately its also not working from otherswitch but we can open telnet session with its own management port.
7 REPLIES 7
don_chiang
Hi Israr,
Sounds like you're using putty? If you want to set up keyboard interactive authentication, you could try this:
https://www.techwalla.com/articles/ho...
Or you could set up ssh keys following this:
https://www.digitalocean.com/communit...
Preferably ssh-copy-id or you may manually copy the public key over.
HTH,
Don
phalguni_nanda
It would also help to clarify if this for Ruckus Cloud-managed APs? For SmartZone controllers? for Switches etc. Cloud managed APs will not have SSH access to AP CLI today (it is a plan for an upcoming release).
hi Phalguni Nanda ,
I am talking about icx-7650 switches.
sunny_gupta
Contributor II
If you haven't, you also need to specify the login method/source, ie:
see this video for more detail info:
https://www.youtube.com/watch?v=9YDvcKA6Om0
https://www.youtube.com/watch?v=0feRVrwQwMQ
