Severe flaw in WPA2 - cracked
153 REPLIES 153
Esteemed Contributor II
Hello, my mistake when I posted the 7731 code yesterday.  No premium support
contract required, but you do need to have a guest account / be registered.
The access permissions are corrected now. Please try your download again.
Thanks and best regards.
Interested to know if anyone has had any response from Ruckus about older versions of code and if patches will be available. Their official announcement on when a patch will be available only goes back to 9.10
https://support.ruckuswireless.com/krack-ruckus-wireless-support-resource-center?_ga=2.221041560.149...
Do you have anything running that will not support 9.10?
Edit: Would be if you have ZoneFlex 7025 AP's running...
Yes, i know of a couple of customers which are 9.7 and also do not have software support.
And if Ruckus provide an upgrade for free to 9.10, your only concern is: Are there any AP's running on their systems that is not supported on 9.10..
