Cloudpath and Azure AD SAML Authentication
paul_harper_8pv
We have an environment where we have got on-prem AD synced with Azure AD, we have just started to implement the cloud hosted cloudpath environment to integrate with our Azure hosted VSZ controllers
What we want to do is have cloudpath use the Azure AD as an authentication server, for BYOD and guest sponsorship. Eliminating the need to open ports to our on-prem AD servers.
I see support for google and others but no documentation for Azure AD
is it supported? has anyone else done it?
Thanks in advance
1 ACCEPTED SOLUTION
brett_nelson_78
Hi all,
This procedure is now officially documented on the Ruckus Support Portal.
https://support.ruckuswireless.com/documents/3686-cloudpath-es-azure-integration-using-saml
27 REPLIES 27
i also need it
wellington.silva@segertech.com.br
@brett_nelson_7860102
HI Brett can you send this to me too. rogerrio.maia@gmail.com
thank you
Hello Sir, kindly send this information to me too. david@clustercommunications.co.ke
David, please find the official doc linked above as Accepted Solution... also here...
http://support.ruckuswireless.com/documents/3686-cloudpath-es-azure-integration-using-saml
peter_wilcox_6u
Can I get the PDF also.  pwilcox@cbac.com
