Showing results forย
Search instead forย
Did you mean:ย
vSZE use H320 connect to SSID cannot get IP
I have exist using H320 connect SSID can't get IP issue.
The project is currently underway.
During the process of installing the H320, sometimes there is a problem that the SSID of the connection cannot be obtained.
If this happens, i will restart the AP and it will be normal.
How can i chek that issue?
2 REPLIES 2
Esteemed Contributor II
Do you have a ticket with your Reseller?
Yes, i have ticket.
