interference reduction
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-08-2015 01:20 AM
i am installing 5unit r700 in a hall of 2000 capacity in what best way can i configure the APs to reduce interference among the 5 APs
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-08-2015 01:26 AM
Do you use standalone mode R700?
If then you'd better use static Channel and using 40Mhz bandwidth in 5GZ.
Chang
Chang
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-08-2015 01:39 AM
the channel shifting is dynamic
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-08-2015 07:57 AM
if it is congested and dense environment, then recommend to use to channelfly auto channel change tech. it is known as smart select in standalone AP's and is on by default.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2015 06:55 AM
thank you for your suggestion
i have done the installation but the challenge is that most of my wireless user are on bgn therefore most of the user could not connect and the challenge of interference on the 2ghz frequency.
please i need your help.
scenario: i have tomorrow to solve this challenge
thanks for your quick response
