info channel-wifi1: unable to find active wlan device for wifi1
I have ZoneFlex R300 standalone AP in place. With latest FW (9.7.1...)
I'm using only 2.4G band with 40Mhz channel width.
May 22 15:46:52 RuckusAP1k local2.err syslog: Parameter value L2 is invalid for parameter Tunnel-Mode
May 22 15:47:04 RuckusAP1k daemon.info hostapd: wlan0: STA 38:59:f9:72:5a:38 IEEE 802.11: associated
May 22 15:47:04 RuckusAP1k daemon.info hostapd: wlan0: STA 38:59:f9:72:5a:38 WPA: pairwise key handshake completed (RSN)
May 22 15:55:48 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 IEEE 802.11: disassociated
May 22 15:57:18 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 IEEE 802.11: associated
May 22 15:57:18 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 IEEE 802.1X: ignored too small Session-Timeout 30, override as 120
May 22 15:57:20 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 IEEE 802.1X: ignored too small Session-Timeout 30, override as 120
May 22 15:57:20 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 WPA: pairwise key handshake completed (RSN)
May 22 15:57:20 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 IEEE 802.1X: authenticated
May 22 16:16:22 RuckusAP1k daemon.info channel-wifi1: unable to find active wlan device for wifi1
May 22 16:46:22 RuckusAP1k daemon.info channel-wifi1: unable to find active wlan device for wifi1
May 22 17:16:22 RuckusAP1k daemon.info channel-wifi1: unable to find active wlan device for wifi1
May 22 17:18:11 RuckusAP1k daemon.info hostapd: wlan0: STA 34:be:00:57:e1:e2 IEEE 802.11: associated
May 22 17:18:11 RuckusAP1k daemon.info hostapd: wlan0: STA 34:be:00:57:e1:e2 WPA: pairwise key handshake completed (RSN)
May 22 17:46:17 RuckusAP1k daemon.info hostapd: wlan0: STA 38:59:f9:72:5a:38 WPA: group key handshake completed (RSN)
May 22 17:46:17 RuckusAP1k daemon.info hostapd: wlan1: STA 60:67:20:05:0b:64 WPA: group key handshake completed (RSN)
May 22 17:46:17 RuckusAP1k daemon.info hostapd: wlan0: STA 34:be:00:57:e1:e2 WPA: group key handshake completed (RSN)
May 22 17:46:22 RuckusAP1k daemon.info channel-wifi1: unable to find active wlan device for wifi1
May 22 17:53:14 RuckusAP1k daemon.info hostapd: wlan0: STA 34:be:00:57:e1:e2 IEEE 802.11: disassociated
What does this mean:
6 REPLIES 6
keith_redfield
Valued Contributor II
Was this unit attached to a ZD at some point? It's acting like it. I would hard-reset and re-configure.
Also...40Mhz channels on 2.4 are generally not advised and rarely provide the anticipated benefit.
As fas as I know, it was not attached to the ZD. I just bought it from store and it was packed like "from facktory"...
I know that 40MHz is not adviced, but if I have a free air and viable performance boost.. why not..?
Anybody?
have you ever factory reset this device? if not do that first or possibly go so far as firmware re-flashing it
if you still have issues try different encryptions/security methods
