how should a Ruckus T310c be mounted?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-17-2020 10:08 AM
i haven't been able to locate any documentation which describes how to mount the T310c.
parallel to ground or perpendicular> and recommend height from ground might be helpful as well.
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2020 11:59 AM
You can find the mounting instructions in the QSG (Quick Setup Guide) on the support portal here including how to attach on a flat surface, to a pole, how to earth grounding, etc.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2020 02:54 PM
i've seen that document. but it doesn't explain how that affects its radio's pattern.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-17-2020 04:22 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-18-2020 02:45 AM
@Tony Heung
The Knowledge Base article with radiation patterns is a great resource, Thank you very much for sharing the link!
Will the article be augmented with 11ax/Wi-Fi 6 AP patterns? At the moment only R750 is there.
