bad firmware header magic
martin_nyokolod
I am trying to upgrade my T300 outdoor AP with the OutdoorAP-100... firmware but I keep getting the "bad firmware header magic" error message. The AP is currently on Unleashed and does not emit wireless, It was previously used with a controller but I don't have a controller at the moment and would like to use it as standalone
6 REPLIES 6
from the looks of it.. it seems to have the firmware from the controller.. so best to reflash it to standalone 104.0.0.0.1347.bl7 solo AP. .. after that do a hard reset and everything see if wifi works.. then reflash it to unleashed. 200.6.10.X is the one I recommend.
Esteemed Contributor II
Martin, you AP shows it was last controlled by an SZ (3.1.2.0.134).
Follow instructions from the KBA Hyak pointed to, and load either a Solo image if you only have this one AP, or Unleashed for T300, which has a different look and feel, and requires you to build an Unleashed network.
Type a product name
