about R550 5G
masaki_matsumur
Only 5G is unstable, connection is lost or SSID is not visible
Does it stabilize if I leave it for a while after installation?
21 REPLIES 21
david_black_594
Contributor III
Is this Unleashed and are you using Channelfly?
@david_black_5940365  No, I simply tried to activate one. Apparently it is an initial defect, so I will contact the distributor. Thank you!
Curious about the initial defect on the r550? Is this a known issue with early production units? I have an install of three r550 (unleashed) that I haven't been able to get stable - same location/placement using r510 displays no issues.
It did not seem to be an initial failure of the unit, and replacing the unit did not fix the problem. We are continuing to verify this.
Type a product name
