ZoneFlex R600 and second ethernet port
gianluigi_fusar
How use the second ethernet port
2 REPLIES 2
gianluigi_fusar
Hello, i would like to ask: can i use the second ethernet port to connect another R600 (which I will eventually connect to a separate power supply)?
Basically i would like to move an R600 from one position to another by connecting it to the second ethernet jack of the nearest R600.
Then, the first POE ethernet port should be forward all to the second ethernet port, also the vlans.
Can be the second ethernet port configured in this way?
Thanks.
Yes, you can "daisy-chain" one (power-supplied) AP with an Ethernet cable from a first active (PoE adapter/switch) AP.
