ZoneFlex R500 Captive Portal without WLC
seshavalli_akel
HI,
I would like to setup a Captive Portal for Zoneflex R500 without using  a WLC, can you please suggest the guidelines, to make the same happen.
3 REPLIES 3
Esteemed Contributor II
You would need an external HotSpot server to host your login page and authentication, if you have only a standalone mode R500 AP.
Other Captive Portal/WebAuth or Guest Access methods do require a ZD controller.
I have a standalone R500AP, please point me to the specs that would need to be in place for the HotSpot server to be setup.
- The packet/protocol exchange on HotSpot server
- The parameters to be passed between HotSpot server and R500
- The configuration to be done in R500
Regards
walter_pellegri
Zoneflex r500
