Zone Director IP vs Netgear Router
john_simoneau
Got a new ZD 12 and T300’s. I bought a basic Netgear Router to setup between the incoming internet line and ZD so it would assign it an IP so I could reach the setup wizard. So I set it up to that IP address but for some reason the router keeps randomly changing the IP.
I even reserved the IP through the Netgear router for the ruckus with that mac address. Seems like it works. Then randomly the IP changes again.
Any ideas?
8 REPLIES 8
krishan_parasha
Contributor
Excluded the ip from router dhcp it should not be change ,,
krishan_parasha
Contributor
And assign static IP to zd still same issue plz send model no of ur router and configuration file as well
macservicecente
I have faced same issue with my netgear router, when I got the setup wizard then I easily set up to that IP address but suddenly the router changes the IP address. So anyone can tell me the reason of suddenly changes the IP address. I didn’t install the hard drive on netgear router then I resolved this issue from this link https://www.netgearroutersupportnumber.com/
emma_smith_52wb
It depends what they what to do with wireless but if it is unreliable it will cost more in wasted time!! I would get some Cisco quotes if they what to see expensive. Ruckus AP generally can support 30 laptops per AP.
https://www.routertechnicalsupportnumbers.com/cisco-router-support/
