ZF7372 DIR LED blinking green
dtsblake_588878
Contributor II
Our ZF7372 worked well for 72 hours or so. Magically, it was "disconnected" per our console on the ZD3000.
Power light is solid green and the DIR light is blinking green. NO other lights 30 seconds after reboot. Just power light is solid green and the DIR light is blinking green.
I could not find any doc that explains the standard LEDs on any current ZF units.
Anyone?
6 REPLIES 6
dtsblake_588878
Contributor II
Tech support issued an RMA to swap.
This after resetting to factor defaults a couple of times and still had the blinking DIR led.
Thanks all.
martin_velk
found out that the PoE switch wasn't connected to the network switch.
