ZD1200 10.0.0.0.1424 (GA)- "Force DHCP Option". Issue with Roaming?
andrew_bailey_7
I've had a problem with Roaming between APs (with 802.11R and 802.11K enabled) on the same WLAN.
Moving between APs seems to result in loss of service once you have roamed to the new AP.
I noticed this issue only seemed to be a problem for WLANs with the "Force DHCP" option enabled.
Turning off the "Force DHCP" option (ie the timeout if DHCP address is not assigned) seems to resolve the issue.
However, I can't see why this would be.
Roaming between APs shouldn't require any DHCP intervention.
Anyone have any ideas why this option might cause problems in roaming?
Has anyone else seen this issue?
Could it be a bug in the new 10.0 release perhaps?
Kind Regards,
Andy.
2 REPLIES 2
