ZD 3000 AP's upgrading loop
user_unix
I have A ZoneDirector 3000 with firmware version 10.2.1.0 build 75. when i try to adopt T300 Or R500 Ap's it's stuck in a loop of Upgrading Ap's Firmware.
Can You Please Help me as soon as possible?
Thanks.
8 REPLIES 8
albert_pierson
Contributor III
Hi
The AP's upgrade their firmware from the Zone Director using FTP on port 21.
Please verify the version of code presently running on the AP's by connecting to the AP's via CLI/SSH - get version.
If the AP's are running unleashed code (200.x) or SCG code (1.x, 2.x, 3.x, 5,x) then you will need to first flash the AP's with the standalone version of code 10x.x (104.x version of code is the most reliable).
Here are some KBA articles that might help:
How to upgrade standalone AP through FTP or local option 
Upgrading standalone AP through FTP or local option
https://support.ruckuswireless.com/articles/000001297
Standalone AP upgrade via CLI
This article gives you information on how to upgrade the standalone AP via CLI.
https://support.ruckuswireless.com/articles/000001551
I hope this information is helpful.
Thanks for selecting Ruckus Networks products, A Commscope company.
It's work's thanks
user_unix
okay thank you for your time.
This should solve your problem:
Make sure FTP is enabled on the ZD. Login to the ZD cli using any SSH tool like PuTTy and type the following commands.
ruckus> en
ruckus# config
ruckus(config)# system
ruckus(config-sys)#ftp
To disable again:
ruckus(config-sys)# no ftp
