We have a mix of both ZF7363 and R600 access points. As we use WLAN groups, how many SSIDs can each access point broadcast?
phillipsca
SSID Broadcasting
2 REPLIES 2
This is management not AP specific and was written before the R600 was on sale, that aside...
 from the Zone Director  online help guide:
The maximum number of WLANs configurable per ZoneDirector controller are as follows:
Model
Max WLANs
ZoneDirector 1100
128
ZoneDirector 1200
256
ZoneDirector 3000
1024
ZoneDirector 5000
2048
On single and dual-band 802.11n APs, the maximum number of service WLANs deployable per AP radio is 27. These APs support maximum 32 SSIDs per radio, but five are reserved (two mesh SSIDs and one each for monitor, recovery and scan).
802.11ac APs support up to 27 service WLANs on the 2.4 GHz radio and 13 service WLANs on the 5 GHz radio.
  • CAUTION!   Deploying a large number of WLANs per AP will have a performance impact. Ruckus Wireless recommends deploying no more than eight WLANs per AP radio.
Each WLAN SSID broadcast takes airtime and reduces the response/efficiency of the APs. It is a real effect. Lots of SSIDs will degrade your wifi network. If I can find the earlier thread on this will post.
The ability to create numerous SSIDs above a practical limit could be for situations where they are switched on and off by schedule.
This article might at least give you pause for thought before using "many" SSIDs
http://www.revolutionwifi.net/revolutionwifi/p/ssid-overhead-calculator.html
not the one I was looking for...  but does have a pretty picture.
