Virtual SmartZone with R610 AP
cristiano_bevil
I have setup my Virtual Smart Zone controller with version 3.6.1.0.227.
I have a ZoneFlexR610 AP but i don't know how to connect it to my controller. Can you explain me how to do that? The AP firmware version is 104.1.0.0.298.
Thanks!
3 REPLIES 3
Esteemed Contributor II
Hi Cristiano,
   Be sure your AP has network connectivity to your SZ.  Use any SSH utility to open a session with your AP.
Default IP is 192.168.0.1, but it might pickup DHCP from your network, and you'll need to search the DHCP
lease table for your AP MAC address.  Default login to a new AP is 'super' and 'sp-admin'.  At the AP prompt,
type 'set scg ip a.b.c.d' (where a.b.c.d is your SZ controller's IP address), then 'reboot'.  This will point your
AP to your controller.  Please let us know if this was helpful.
Hello Michael, thanks!
Must it be the Management, Control or Cluster ip of the controller?
Thanks!
I think that it may me the controller Control ip, but it is unreachable.
If i ping the management ip, that's ok, but if i ping the control ip it does not work. Is there something i need to do to make the Control ip reachable?
Thanks!
