Virtual SmartZone html login form example
Does someone has a captive portal login form with POST action and required hidden fields example to use with VirtualSmartZone?
Thanks!
6 REPLIES 6
vivek_gupta_eaj
Hi Cristiano,
May be you can you try this below . Replace x.x.x.x with the ZD IP address.
Wireless Internet Service
" rel="nofollow" target="_blank" title="Link http//172181102319997/login">http://x.x.x.x:9997/login">;
Username:
Password:
Vivek Gupta
Thanks! I'm going to use this with Zone Director.
Hi.
If you use above code, you'll meet failure to authentication because SZ an ZD have different form code.
function get_param(name)
    if (location.href.indexOf("?") >= 0)
        var query=location.href.split("?")[1];
        var params=query.split("&");
        for (var i = 0; i < params.length; i ++) {
             value_pair=params[i].split("=");
            if (value_pair[0] == name)
                 return unescape(value_pair[1]);
    return "";
function get_sip() {
    var sip = get_param("sip");
   //var sip = "172.21.144.65"; -----> if you need to static ip, write the ip here
    if (sip.indexOf(":") < 0) { // IPv4 address
        return sip;
    } else {                    // IPv6 address
        return '[' + sip + ']';
Wireless Internet Service for SmartZone
document.write('
http://' + get_sip() + ':9997/SubscriberPortal/hotspotlogin">');
document.write('');
document.write('');
document.write('');
document.write('');
Username:
Password:
Above code will be parsing to controller ip automatically.
Regards.
Thanks! This is the correct example for Virtual SmartZone. Worked ok!
