Virtual Smart Zone -High Several AP firmware
ivan_gonzalez_g
In the platform Ruckus VSZ-H there is the possibility to load several firmware to support old AP(Example: ZF7343). In the literature says that each zone can have a firmware. Any information or link where you can find help.
Best Regards
16 REPLIES 16
Not true. We have 9 versions on our vSZ
9 firmware versions?
Yes - not all in use of courseImage_ images_messages_5f91c46f135b77e247a83c48_2ac317292c2be38f47477402f4e4bf24_RackMultipart2017030311082215s-20168433-ff80-4577-a1e5-c6fc0e7bfc38-1582321278.jpg1488558740
Thank you very much for the information and help.
I am trying to install the version that I recommend (version 3.1.1.0.323). For the high scale version, when configuring it tells me that the properties of the cluster have failed. This error does not occur when I install version 3.2.1.0.163 or higher.
How to get to the current version 3.1.536 to the 3.2.0.163 high-scale version 3.1
