There's any way to limit the number of clients per SSID on each AP?
nuno_pimentel
Contributor
There's any way to limit user of each AP per SSID ?
For example  If i'm deploying several SSID in the same AP i would like to limit the number max of clients in each AP, that should be an interesting feature for example:
i have : 3 SSID like
public wifi open
org wifi: WPA2
media wifi: WPA2
and i would like to limit the the public wifi to use max: 50% of availability of the AP and the other with quotes of 25% each.
Is this possible to configure ?
I know that there are the option of mark an SSID as priority low or high, but how does ZD work in this situation? like in this example if i have all max  clients connected in the public wifi and someone wants to connect "org wifi" or "media wifi" ?
regards
3 REPLIES 3
max_o_driscoll
Valued Contributor
Places where you can configure client connections in ZD.
1. Access Point Groups
configure...access points...access point groups
Image_ images_messages_5f91c40d135b77e24793a35e_dc780642e4e42bb9e1a0c025647749a4_RackMultipart2015030694547itqn-ceadfa54-216a-42f8-b112-65896e63a14e-774780117.jpg1425656462
2. WLANs
configure...wlans
Image_ images_messages_5f91c40d135b77e24793a35e_76040ed39f867762cfd67761b9b2f676_RackMultipart20150306241121glk-582f9800-b261-4345-94ea-0e8622ee295a-691330692.jpg1425656622
Combination of these two settings should give you some control.
max_o_driscoll
Valued Contributor
There is a %priority setting but that is another issue.
I've just shown where you can configure max client connections.
nuno_pimentel
Contributor
Thanks for the quick answer it will help for sue. But by the way why is another issue? How it work this priority i never understand quite well and in the manual it's not very specific how ti works, or if only works if we force the traffic pass in the ZD.
