TACACS+ on ZoneFlex P300
pierre_pierre_c
I try to configure TACACS+ on my ZoneFlex P300 with my Cisco ACS 5.8, but it's not working.
On the ACS i can see "Wrong password or invalid shared secret" , but the shared secret and the user password are working....
Is it specific attribute for ZoneFlex with ACS ?
thanks in advance for your feedback.
Best regard
5 REPLIES 5
Esteemed Contributor II
You mean the P300 outdoor point-to-point bridge?  And what are you trying to configure to use TACACS+ authentication, the login to the AP or its WLAN?
See the P300 User Guide, page 38 begins the details on setting up TACACS+ admin login access, and must include one of three admin privilege levels.
https://support.ruckuswireless.com/documents/804-zoneflex-p300-release-100-1-0-9-43-ga-user-guide
pierre_pierre_c
Finally it's working, but the end user password do not contain a "$" .
When there is a $ on the password it's not working.
Best regard
Thanks for your feedback too Pierre, this is something I'll capture in a Knowledge Base Article.
I've also requested an example of the ACS side setup for an AP Admin login from Engineering,
which I don't have for the article.  If I email you, can you share an example from your TACACS+
setup?
monnat_systems
Valued Contributor II
as far i know while working with one end customer with similar issue with AD password containing $ were not working and it turned out Ruckus does NOT like passwords with $ and there was a bug opened for the same. not sure.. if that got sorted.
That was years ago and for controller and AP's
