Standalone AP R500, RADIUS NSP, PEAP
Hello. Our company testing two AP R500 in standalone mode. I want to set up RADIUS Auth on APs with Windows 2012 NPS. But AP does auth through EAP protocol, not PEAP. I cant find where can I change it or it is impossible without controller? Please help!
2 REPLIES 2
Esteemed Contributor II
Ruckus 802.1x EAP support includes PEAP.
Under Configuration / Radio 2.4G (or 5G), and a WLAN tab, specify the Encryption Method = WPA, with the WPA Authentication of 802.1x,
and enter your Win2012 NPS server IP address, port 1812, and a Shared Secret in the Authentication Server fields.
Then when you connect a client, you'll use whatever supplicant method to enter your Userid/Password (for AD auth).
Thanks for reply. I entered all fields about RADIUS server, config NPS server but it does not work. I have 8 Unifi APs with software controller and they are working with current RADIUS server and configuration. In my NPS server in log files I see that auth on ruckus is using EAP protocol instead PEAP.
