09-10-2015 10:34 AM
09-10-2015 04:36 PM
KBA-1968: How to disable Ethernet port on the AP
The way to disable the ethernet ports on the AP to avoid users to plug in to the un-used ports and bypass authentication.
Below are the commands which are tested and found to be working.
In case the Ap is a stand alone Ap :
Login to the command line interface of the AP using putty .
Execute the command "get eth" to dispaly the current status of the ethernet ports on the stand alone Ap.
Identify
the ethernet port number which have to be enabled/ disabled and execute
the command "set eth
In case the Ap is managed by a zone director :
Login to the command line interface of the zone director and get in to the enable mode.
Ruckus>en
Ruckus#debug
Ruckus(debug)#remote_ap_cli
-a
Identify the interface which have to be enabled or disabled and run the below command.
set eth eth0/1/2 enable/disable
