Very true
Once you understand the above explained part then you must need to setup Asus router.
We are not going to waist your time for describing about router or why this occurs. Just Read for simple or perfect solution
Asus Router login.
Wireless routers are terribly simple to line up...
Steps to setup wireless router areas follows :-
-> Connect your router with any PC/Laptop exploitation local area network cable.
-> Open browser and sort 192.168.1.1 within the address bar.
-> If it asks for username and secret enter as:-
Username - admin
secret - admin
-> The default setting page can open when pressing enter key.
-> set up your settings by following the directions provided.
-> Set a secret for security (WPA2) if you would like one.
-> Save your settings and exit the page.
By following the higher than mentioned steps you'll be able to set up any router no matter it's complete... Hope it helps...
