Ruckus ZoneFlex 7982 continuous reboot
leonardo_romane
I have a Ruckus ZoneFlex 7982 and after a couple of days disconnected due to a vacations' trip the AP is performing continuous reboots.
No changes in the configuration. The AP is configured as bridge and get the internet from a DSL router (PPPoE).
The support log shows the following:
Jan 2 14:52:21 RuckusAP daemon.warn Eved: Last Reboot Reason: application reboot
Jan  2 14:52:27 RuckusAP local2.err syslog: Parameter value L2 is invalid for parameter Tunnel-Mode
Jan  2 14:52:33 RuckusAP user.info kernel: br0: port 3(wlan0) entering disabled state (hostapd,423)
Jan  2 14:52:33 RuckusAP user.info kernel: br0: port 3(wlan0) entering learning state (hostapd,423)
Jan  2 14:52:34 RuckusAP user.info kernel: br0: port 3(wlan0) entering forwarding state (swapper,0)
Jan  2 14:52:42 RuckusAP cron.notice ntpclient[690]: Using server: ntp.ruckuswireless.com
Jan  2 14:52:43 RuckusAP cron.notice ntpclient[690]: Time set from remote server
Jan  2 14:52:43 RuckusAP cron.notice ntpclient[690]: Skew 31.6mS, freq adjust 0
Jan  2 14:52:43 RuckusAP cron.notice ntpclient[692]: Using server: ntp.ruckuswireless.com
Jan  2 14:52:43 RuckusAP cron.notice ntpclient[692]: Time set from remote server
Jan  2 14:52:43 RuckusAP cron.notice ntpclient[692]: Skew 265.2mS, freq adjust 0
Jan  2 14:52:57 RuckusAP daemon.notice rsmd_func[713]: Monitor: APMgr process not alive
Jan  2 14:52:57 RuckusAP daemon.err rsmd[66]: Receive reboot msg [a,1]
Any ideas?
12 REPLIES 12
seanmuir
Contributor III
what version are you on?
leonardo_romane
Firmware? I have updated it to the latest one.
Base 100 image?
leonardo_romane
Not sure I got your question....is it still about the firmware?
Type a product name
