05-03-2016 10:32 AM
I've been doing many web searches for a small PoE+ switch that is known to work well with the R710, but it seems like all I can find is stories about switches with problems not working with 802.3at and the R710.
I need to find a small, inexpensive PoE+ switch (8 ports) to supply power to a max of five R710 APs. It needs to support 802.1q vlans since it will be connected to an upstream switch that is Cisco Catalyst family. It also needs to be pretty inexpensive too... I spent almost all of my budget for this project on five R710s and a ZoneDirector 1200.
Is there a brand and model of inexpensive PoE+ switch that is absolutely 100% known to just simply work with the R710 without a bunch of config hassles or other wierdnesses?
05-03-2016 11:31 AM
05-03-2016 02:25 PM
05-03-2016 03:12 PM
Someone else posted that the entire Cisco SG300 line is no-go with the R710 and negotiating 802.3at power. I can't remember where I read that though.... I was already looking at the SG300-10MPP as a possible candidate when I found the post.
I may just have to run this new set of R710 APs on legacy 802.3af instead. I just found I had a spare Cisco compact C3560 8-port 10/100 switch that got removed from a remote office and it's got 124W of PoE capacity. The Internet feed that will be supplying this installation is only 50Mbps anyway, so that will be the real bandwidth bottleneck, and not the 10/100 ports of the switch. Maybe next year I can get the budget for a PoE+ gigabit switch to get rid of the radio limitations of running the R710 on 802.3af power.
05-03-2016 03:19 PM
