Radius/802.1X Authentication
anderson_janoni
It's possible configure the access point with enterprise authentication (802.1x/Radius) without using a Zone Director?
I'm thinking buy a R300 Access Point.
Ty.
2 REPLIES 2
Esteemed Contributor II
Yes, you can define up to 8 WLAN/SSIDs on each radio, 2.4G and 5G, with different
security methods. WPA encryption, can be used with a PSK or 802.1x/RADIUS.
If you specify WPA with 802.1x, you'll find fields to enter your AAA server IP, port,
and shared secret key for authentication, and optionally, for accounting too.
munish_munish
Contributor
Hi Anderson,
Yes, as Michael answered. Here is the print screen for you reference .
Image_ images_messages_5f91c414135b77e247950f48_52ad1df4f1d6d7236eb9a0c27d636f31_Capture_inline-4353b0b7-5aec-4b2e-8e05-21b447844a35-154837290.JPG1421185650
Munish
