R850 - poor performance on 2.4
Vims
We have 60 AP R710/R720/R510/R310
We have replace some R700 with R850 AP
We have a VSZ 6.1.0.0.935 an AP 6.1.0.0.1595
All R850 are connected with Ruckus 2.5 G supported POE+ switch
Internet connection is 1Gb fiber
When we try to connect in 2.4GHz, the mobile devices seems works well with R710/510... only.
On all 7 R850 a any Mobile new or old,  doesn't get the speed above 10 Mb. Most of the times it remains even less than 1 Mb. (sometimes 0.03... I don't know how i can connect to website for testing 😄 )
It's a public space so i can't tweak the client.
Any advice ?
Regards
7 REPLIES 7
Parik_MN
RUCKUS Team Member
Hello @Vims
R850 APs minimum operating power is AT mode. Could you please run below CLI command and check if the power consumption is AT and more or is it just AF.
get power-mode
Below command to enable AT power. It's better to get 35+ Watts of PoE power injector or similar PoE switch to support BT5 power standards, so that AP can turn on full operating mode.
set power-mode AT
Parik
Vims
Thanks for the reply.
We are in bt mode
rkscli: get power-mode
PoE Configured Mode : bt5
Power Consumption Status : 802.3bt5 Switch/Injector
USB Status : Enabled
Could it be due to Wifi6 ? I'm looking for the way to desactivate it for test.
Regards
Parik_MN
RUCKUS Team Member
Hello @Vims
Yes, you can try disabling wifi6 feature and test. For further investigation and assistance feel free to open a Support Case.
Parik
Vims
Thanks.
Do you know how to disable it ?
Regards
