01-13-2025 03:23 PM
I have two R770 Access Points and I would like to assign an SSID to a single WAP. I have a camera that is closer to one of the WAPs and I would like to have a separate SSID only available on that WAP to ensure that it is connecting to the closest access point.
I can't figure out how to configure this, can someone share the steps with me?
01-22-2025 12:48 PM
If the AP are on standalone mode, then you can configure separate SSID on both the AP.
Login to the AP and under the Configuration --> Radio 2.4G --> enter the details and save the configuration, Similarly you can configure the same SSID on Radio 5G as well so that the SSID can be broadcasted on both the Radios, however, if you want the SSID to be configured on single Radio you can choose one of them.
Yogesh G
