You say the following:
oh and we have 45mpbs+30mbps = 75mbps WAN line which are club together
Are these WAN links load balanced?
If you were to do the math on your WAN, and look at your backhaul in relationship to you concurrent user volume. If all your clients were on at once they would share the WAN and be able to pass 357Kbps each - this is not a lot.
Network design always starts at application demand and the number of clients which demand the use of that application and the value associated to that application.
Example:
Lets say your application is 4Mbps
Your client count is 210 with a client radio split of 65% - meaning your busiest frequency would have 137 clients on it.
Lets also say your Max TCP throughput of the AP radio (802.11ac using a 40MHz Channel and a single spatial stream) is 70Mbps on the DL.
Your cell edge deisgn is -61dBm (based on IEEE values for 64QAM bitrate)
The airtime required for a 4Mbps constant stream would be as follows:
1x1 Client = 5.93% @ Top Bitrate
If you then look at your client limit of 137 the total airtime to pass the demand for the application at once would be 811.85%.
Your happy airtime is 75%.
This would mean that you need 11 AP's to deliver the application to client numbers.
You would also need a backhaul of 840Mbps.
As you can RF is one thing, but you have to base your RF on what your network demand is first.
