08-02-2019 01:00 AM
Aug 2 07:59:41 Ruckus-Unleashed-R510-b0 syslog: AP get the broadcast ip in its subnet, the broadcast ip is x.y.z.255x.y.z.252 is the reserved IP. The problem is if I were to disable reservation I'd never login and obtain the logs before the WAN IP changes again.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, debug_init[82]: Set log_level file to [/tmp/pubnubd_loglevel].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd: set debug_log_level to 3, internal log_level to 1.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, main[729]: missing publish-key|subscribe-key|channel-name, pending service.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[644]: state change [(null)]->[PENDING].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[664]: 'Fri Aug 2 07:59:43 2019': service recovered
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pid=1160, monitor():FileCache synced
Aug 2 07:59:44 Ruckus-Unleashed-R510-b0 rsmd[86]: tacmon .......... [stopped] (0.020)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslogd (inetutils 1.4.0): restart (remote reception)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 sys_wrapper: Start Bind DHCP server
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslog: sqlited, adding AP group: 1, wlangrp_id[0]=1, wlangrp_id[1]=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: (ap state) AP begin to join ac.
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: Cannot notify kernel for Upd AP Param x.y.z.252(0) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 ZD-APMgr: Cannot notify kernel for Upd AP Param x.y.z.252(12225) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: WTP join cfm response, lwapp_notify_kernel_ip_addr [nat ipv4]. nat_ipv4_addr: x.y.z.252 port: 0 family: 2
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: System time was synced
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me, 4685 Failed to set set lbs port(parameter value out of range)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: eventd_to_syslog():AP[M:A:C:A:D:D] joins with uptime [132] s and last disconnected reason [AP Restart : power cycle]
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me: setting ip mode, before=1, now=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: [lwapp_update_wtp_vendor:7434] : company=4bss, strlen(company)=4
