08-02-2019 01:00 AM
Aug 2 07:59:41 Ruckus-Unleashed-R510-b0 syslog: AP get the broadcast ip in its subnet, the broadcast ip is x.y.z.255x.y.z.252 is the reserved IP. The problem is if I were to disable reservation I'd never login and obtain the logs before the WAN IP changes again.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, debug_init[82]: Set log_level file to [/tmp/pubnubd_loglevel].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd: set debug_log_level to 3, internal log_level to 1.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, main[729]: missing publish-key|subscribe-key|channel-name, pending service.
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[644]: state change [(null)]->[PENDING].
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pubnubd_debug: pid=2070, handle_state_change[664]: 'Fri Aug 2 07:59:43 2019': service recovered
Aug 2 07:59:43 Ruckus-Unleashed-R510-b0 syslog: pid=1160, monitor():FileCache synced
Aug 2 07:59:44 Ruckus-Unleashed-R510-b0 rsmd[86]: tacmon .......... [stopped] (0.020)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslogd (inetutils 1.4.0): restart (remote reception)
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 sys_wrapper: Start Bind DHCP server
Aug 2 07:59:46 Ruckus-Unleashed-R510-b0 syslog: sqlited, adding AP group: 1, wlangrp_id[0]=1, wlangrp_id[1]=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: (ap state) AP begin to join ac.
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: Cannot notify kernel for Upd AP Param x.y.z.252(0) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 ZD-APMgr: Cannot notify kernel for Upd AP Param x.y.z.252(12225) event, -- No such file or directory(2)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: WTP join cfm response, lwapp_notify_kernel_ip_addr [nat ipv4]. nat_ipv4_addr: x.y.z.252 port: 0 family: 2
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: System time was synced
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me, 4685 Failed to set set lbs port(parameter value out of range)
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: eventd_to_syslog():AP[M:A:C:A:D:D] joins with uptime [132] s and last disconnected reason [AP Restart : power cycle]
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: lwapp_proc_vendor_me: setting ip mode, before=1, now=1
Aug 2 07:59:57 Ruckus-Unleashed-R510-b0 syslog: [lwapp_update_wtp_vendor:7434] : company=4bss, strlen(company)=4
08-02-2019 02:22 PM
08-02-2019 11:13 PM
Aug 2 04:39:55 cid_l 7 cidp 1 mac 0x74 3e 2b M A C htype 1 subnet c0a803fe ifindx 0 key_type 1
Aug 2 04:39:55 DHCPv4 client entry ADDED, app_type 1 routing context default:default
Aug 2 04:39:55 Service_get NO service name
Aug 2 04:39:55 jdhcpd_sdb_create_session: phy device name vlan
Aug 2 04:39:55 jdhcpd_sdb_create_session: INET, setting LR name default
Aug 2 04:39:55 jdhcpd_sdb_create_session: INET, setting RI name default
Aug 2 04:39:55 jdhcpd_sdb_create_session: INET, setting underlying interface vlan.0
Aug 2 04:39:55 jdhcpd_sdb_create_session: INET, setting logical if name vlan.0
Aug 2 04:39:55 jdhcpd_sdb_create_session: INET, setting MAC addr 74:3e:2b:M:A:C
Aug 2 04:39:55 jdhcpd_session_db_create_v4_session_attributes: INET, setting IP addr Key x.y.z.254
Aug 2 04:39:55 jdhcpd_session_db_create_v4_session_attributes: INET, dhcp_options len 40, data 35 01 01 3d 07 01 74 3e 2b M A C 3c 0a 52 75 63 6b 75 73 20 43 50 45 39 02 02 40 37 0a 01 02 03 06 0c 0f 1c 2a 2b 2c
Aug 2 04:39:55 jdhcpd_sdb_create_session: session DB create got INET entry id 11
Aug 2 04:39:55 Mirroring disabled (ha_graceful_switchover false) 0.0.0.0
Aug 2 04:39:55 Allocated memory to store in SDB, sizeof(jdhcpd_ha_client_header_t) 88 + total_tlvs_len 85 (sizeof(client->session_id) is 11)
Aug 2 04:39:55 Saved NON-DEMUX interface name vlan.0 into mirroring ha_info
Aug 2 04:39:55 Added TLV for DHCPv4 CLIENT ID from client key, length 7
Aug 2 04:39:55 Added TLV for DHCPv6 LinkLocal Address, length 16
Aug 2 04:39:55 Successfully saved private data for 0.0.0.0 in SDB, length 173
Aug 2 04:39:55 SDB ACK will notify us for LOCAL-SERVER client session Id 11
Aug 2 04:39:55 Successful SDB Mirrored Ack: returned code SDB_SUCCESS for session id 11
Aug 2 04:39:55 SDB mirroring ACK received
Aug 2 04:39:55 jdhcpd_auth_request: auth-request attempt initiated for session 11: flags1:0x20000; flags2:0
Aug 2 04:39:55 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:39:55 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:39:55 Added client w/ session_id 11 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:39:55 using Service-Profile-Name
Aug 2 04:39:55 jdhcpd_authenticate_rply_proc: Got reply for auth_request, reply auth_rqst_id = 65549- (session Id 11)
Aug 2 04:39:55 Request to remove client w. session_id 11 in state 1 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:39:55 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:39:55 jdhcpd_authenticate_rply_proc: auth login reply status for session 11: result:1; flags1:0x20000; flags2:0x10
Aug 2 04:39:55 got IP address jdhcpd_session_db_client_info_get x.y.z.251
Aug 2 04:39:55 got net mask jdhcpd_session_db_client_info_get 255.255.255.0
Aug 2 04:39:55 got ls name jdhcpd_session_db_client_info_get default
Aug 2 04:39:55 got ri name jdhcpd_session_db_client_info_get default
Aug 2 04:39:55 got pool name DefaultPool, len 11
Aug 2 04:39:55 Auth request reply ip x.y.z.251, pool name DefaultPool
Aug 2 04:39:55 jdhcpd_pool_find: cfg 7d8000, pool_name 8caf10, DefaultPool
Aug 2 04:39:55 jdhcpd_pool_find: Pool DefaultPool found 0x7e0800 w/ cfg container 0x7d8000
Aug 2 04:39:55 Got AUTH reply- no profile- LOCAL_SERVER_STATE_CLIENT_SELECTING, updating SDB with client session state SDB_SESSION_STATE_CONFIGURED
Aug 2 04:39:55 jdhcpd_session_db_client_session_state_set: setting session state 1
Aug 2 04:39:55 jdhcpd_session_db_client_session_state_set: setting action bits to 3, config-bits:0x2 0 0 0 0
Aug 2 04:39:55 libstats clear iflstats passed session_id 11
Aug 2 04:39:58 cid_l 7 cidp 1 mac 0x74 3e 2b M A C htype 1 subnet c0a803fe ifindx 0 key_type 1
Aug 2 04:39:58 jdhcpd_pool_find: cfg 7d8000, pool_name 8caf10, DefaultPool
Aug 2 04:39:58 jdhcpd_pool_find: Pool DefaultPool found 0x7e0800 w/ cfg container 0x7d8000
Aug 2 04:39:58 rc_entry_sus_find_ipaddr: TYPE 1 for IP ADDR x.y.z.254 in routing context LR default/RI default
Aug 2 04:39:58 Entry w/ ref_count 1 found when searching 'subunit by ip-addr' for IP ADDR x.y.z.254 in routing context LR default/RI default
Aug 2 04:39:58 jdhcpd_auth_profile_activate: auth activate req for session 11: flags1:0x20000; flags2:0x10
Aug 2 04:39:58 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:39:58 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:39:58 Added client w/ session_id 11 in state LOCAL_SERVER_STATE_CLIENT_SELECTING, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:39:58 jdhcpd_service_activated_rply_proc: Got service-activated reply rqst_id = 65549 (session Id 11)
Aug 2 04:39:58 Request to remove client w. session_id 11 in state 16 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:39:58 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:39:58 Mirroring disabled (ha_graceful_switchover false) x.y.z.251
Aug 2 04:39:58 Allocated memory to store in SDB, sizeof(jdhcpd_ha_client_header_t) 88 + total_tlvs_len 85 (sizeof(client->session_id) is 11)
Aug 2 04:39:58 Saved NON-DEMUX interface name vlan.0 into mirroring ha_info
Aug 2 04:39:58 Added TLV for DHCPv4 CLIENT ID from client key, length 7
Aug 2 04:39:58 Added TLV for DHCPv6 LinkLocal Address, length 16
Aug 2 04:39:58 Successfully saved private data for x.y.z.251 in SDB, length 173
Aug 2 04:39:58 SDB ACK will notify us for mirroring ADD for x.y.z.251, client session Id 11
Aug 2 04:39:58 Successful SDB Mirrored Ack: returned code SDB_SUCCESS for session id 11
Aug 2 04:39:58 Atemmpt to jdhcpd_rtsock_do_arp for non-PASSIVE client x.y.z.251, ifindex 69, l2 ifindex 0
Aug 2 04:39:58 jdhcpd_rtsock_do_arp: L3ifindex (ifs) = 69, L2ifindex 0, addr_fam INET, operation 1
Aug 2 04:39:58 Add media route for x.y.z.251 on interface vlan.0 (hw 74:3e:2b:M:A:C) perm
Aug 2 04:39:58 SUCCESSFULL Add media route for x.y.z.251 on interface vlan.0 (hw 74:3e:2b:M:A:C) perm, l2Int
Aug 2 04:39:58 ARP add for media successful for x.y.z.251
Aug 2 04:39:58 Table Id 0x1000000:Added ACTIVE ROUTE x.y.z.254 index 69 giaddr x.y.z.254
Aug 2 04:39:58 Updating SDB with client session state 2
Aug 2 04:39:58 Marked SDB state ACTIVE, client in FSM state LOCAL_SERVER_STATE_WAIT_SDB_ACTIVE_MIRROR_REQ, SDB ACK will notify us for client session Id 11
Aug 2 04:39:58 Add route success for x.y.z.251
Aug 2 04:39:58 Received event 16 in state LOCAL_SERVER_STATE_WAIT_SDB_ACTIVE_MIRROR_REQ
Aug 2 04:39:58 SDB mirroring ACK received in state 24 (LOCAL_SERVER_STATE_WAIT_SDB_ACTIVE_MIRROR_REQ), changing state to LOCAL_SERVER_STATE_WAIT_SUBSCR_ADD
Aug 2 04:39:58 TESTPOINT: after SDB ACTIVE, ACK received in state LOCAL_SERVER_STATE_WAIT_SDB_ACTIVE_MIRROR_REQ
Aug 2 04:39:58 Received event CLIENT_EVENT_SUBSCRIBER_ACK in state LOCAL_SERVER_STATE_WAIT_SUBSCR_ADD
Aug 2 04:39:58 Found subunit stack in state LOCAL_SERVER_STATE_WAIT_SUBSCR_ADD
Aug 2 04:39:58 Set state to LOCAL_SERVER_STATE_BOUND
Aug 2 04:40:30 cid_l 7 cidp 1 mac 0x74 3e 2b M A C htype 1 subnet c0a803fe ifindx 0 key_type 1
Aug 2 04:40:30 Deleting ROUTE x.y.z.251
Aug 2 04:40:30 Delete route success for x.y.z.251
Aug 2 04:40:30 jdhcpd_rtsock_do_arp: L3ifindex (ifs) = 69, L2ifindex 0, addr_fam INET, operation 3
Aug 2 04:40:30 Delete media route for x.y.z.251 on interface vlan.0 (hw 74:3e:2b:M:A:C)
Aug 2 04:40:30 SUCCESSFULL Delete media route for x.y.z.251 on interface vlan.0 (hw 74:3e:2b:M:A:C), l2Int
Aug 2 04:40:30 ARP delete for media successful for x.y.z.251
Aug 2 04:40:30 In state LOCAL_SERVER_STATE_WAIT_SUBSCR_DELETE, moving to LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE
Aug 2 04:40:30 jdhcpd_auth_release: auth logout initiated for session 11 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE: flags1:0x10000; flags2:0x10
Aug 2 04:40:30 jdhcpd_auth_release_common: Release authd (request user logout): updating SDB with client session state SDB_SESSION_STATE_TERMINATING
Aug 2 04:40:30 jdhcpd_session_db_client_session_state_set: setting session state 3
Aug 2 04:40:30 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:30 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:30 Added client w/ session_id 11 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:30 jdhcpd_auth_release_common: auth logout requested for session 11 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE: flags1:0x10000; flags2:0x10
Aug 2 04:40:30 jdhcpd_user_logout_rply_proc: Got reply for user_logout, reply rqst_id = 65549 (session Id 11)
Aug 2 04:40:30 Get SDB STATE for session Id 11
Aug 2 04:40:30 Got SDB SESSION STATE 3 for client session Id 11
Aug 2 04:40:30 jdhcpd_user_logout_rply_proc: Got authd reply for user_logout in SDB state TERMINATING, for client x.y.z.251, client session Id 11
Aug 2 04:40:30 Request to remove client w. session_id 11 in state 4 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:30 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:40:30 In state LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ: starting updating SDB with client session state SDB_SESSION_STATE_TERMINATED
Aug 2 04:40:30 In client state LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ: updating SDB with client session state SDB_SESSION_STATE_TERMINATED
Aug 2 04:40:30 jdhcpd_session_db_client_session_state_set: setting session state 4
Aug 2 04:40:30 Set to LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ, SDB ACK will notify us for LOCAL-SERVER client session Id 11
Aug 2 04:40:31 Successful SDB Mirrored Ack: returned code SDB_SUCCESS for session id 11
Aug 2 04:40:31 LOCAL-SERVER: SDB mirroring ACK received in client state 26
Aug 2 04:40:31 jdhcpd_auth_release_terminated: auth terminate initiated for session 11: flags1:0x10000; flags2:0x10
Aug 2 04:40:31 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:31 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:31 Added client w/ session_id 11 in state LOCAL_SERVER_STATE_WAIT_CM_DELETE, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:31 jdhcpd_auth_release_terminated_common: auth terminate request for session 11: flags1:0x10000; flags2:0x10
Aug 2 04:40:31 jdhcpd_user_terminated_rply_proc: Got user-session terminated REPLY from authd- reqId 65549, for client session Id 11
Aug 2 04:40:31 Request to remove client w. session_id 11 in state 5 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:31 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:40:31 ATTEMPT TO DELETE libstats; session_id = 11
Aug 2 04:40:31 libstats delete stats: passed session_id 11
Aug 2 04:40:31 Deletion of baseline stats for session id 11 succeeded (client index 65549)
Aug 2 04:40:35 cid_l 7 cidp 1 mac 0x74 3e 2b M A C htype 1 subnet c0a803fe ifindx 0 key_type 1
Aug 2 04:40:35 DHCPv4 client entry ADDED, app_type 1 routing context default:default
Aug 2 04:40:35 Service_get NO service name
Aug 2 04:40:35 jdhcpd_sdb_create_session: phy device name vlan
Aug 2 04:40:35 jdhcpd_sdb_create_session: INET, setting LR name default
Aug 2 04:40:35 jdhcpd_sdb_create_session: INET, setting RI name default
Aug 2 04:40:35 jdhcpd_sdb_create_session: INET, setting underlying interface vlan.0
Aug 2 04:40:35 jdhcpd_sdb_create_session: INET, setting logical if name vlan.0
Aug 2 04:40:35 jdhcpd_sdb_create_session: INET, setting MAC addr 74:3e:2b:M:A:C
Aug 2 04:40:35 jdhcpd_session_db_create_v4_session_attributes: INET, setting IP addr Key x.y.z.254
Aug 2 04:40:35 jdhcpd_session_db_create_v4_session_attributes: INET, dhcp_options len 41, data 35 01 01 3d 07 01 74 3e 2b M A C 3c 0c 75 64 68 63 70 20 31 2e 31 35 2e 32 39 02 02 40 37 09 01 02 03 06 0f 1c 2a 2b 2c
Aug 2 04:40:35 jdhcpd_sdb_create_session: session DB create got INET entry id 12
Aug 2 04:40:35 Mirroring disabled (ha_graceful_switchover false) 0.0.0.0
Aug 2 04:40:35 Allocated memory to store in SDB, sizeof(jdhcpd_ha_client_header_t) 88 + total_tlvs_len 85 (sizeof(client->session_id) is 12)
Aug 2 04:40:35 Saved NON-DEMUX interface name vlan.0 into mirroring ha_info
Aug 2 04:40:35 Added TLV for DHCPv4 CLIENT ID from client key, length 7
Aug 2 04:40:35 Added TLV for DHCPv6 LinkLocal Address, length 16
Aug 2 04:40:35 Successfully saved private data for 0.0.0.0 in SDB, length 173
Aug 2 04:40:35 SDB ACK will notify us for LOCAL-SERVER client session Id 12
Aug 2 04:40:36 Successful SDB Mirrored Ack: returned code SDB_SUCCESS for session id 12
Aug 2 04:40:36 SDB mirroring ACK received
Aug 2 04:40:36 jdhcpd_auth_request: auth-request attempt initiated for session 12: flags1:0x20000; flags2:0
Aug 2 04:40:36 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:36 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:40:36 Added client w/ session_id 12 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:36 using Service-Profile-Name
Aug 2 04:40:36 jdhcpd_authenticate_rply_proc: Got reply for auth_request, reply auth_rqst_id = 65550- (session Id 12)
Aug 2 04:40:36 Request to remove client w. session_id 12 in state 1 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:40:36 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:40:36 jdhcpd_authenticate_rply_proc: auth login reply status for session 12: result:1; flags1:0x20000; flags2:0x10
Aug 2 04:40:36 got IP address jdhcpd_session_db_client_info_get x.y.z.251
Aug 2 04:40:36 got net mask jdhcpd_session_db_client_info_get 255.255.255.0
Aug 2 04:40:36 got ls name jdhcpd_session_db_client_info_get default
Aug 2 04:40:36 got ri name jdhcpd_session_db_client_info_get default
Aug 2 04:40:36 got pool name DefaultPool, len 11
Aug 2 04:40:36 Auth request reply ip x.y.z.251, pool name DefaultPool
Aug 2 04:40:36 jdhcpd_pool_find: cfg 7d8000, pool_name 8caf10, DefaultPool
Aug 2 04:40:36 jdhcpd_pool_find: Pool DefaultPool found 0x7e0800 w/ cfg container 0x7d8000
Aug 2 04:40:36 Got AUTH reply- no profile- LOCAL_SERVER_STATE_CLIENT_SELECTING, updating SDB with client session state SDB_SESSION_STATE_CONFIGURED
Aug 2 04:40:36 jdhcpd_session_db_client_session_state_set: setting session state 1
Aug 2 04:40:36 jdhcpd_session_db_client_session_state_set: setting action bits to 3, config-bits:0x2 0 0 0 0
Aug 2 04:40:36 libstats clear iflstats passed session_id 12
Aug 2 04:40:41 cid_l 7 cidp 1 mac 0x74 3e 2b M A C htype 1 subnet c0a803fe ifindx 0 key_type 1
Aug 2 04:40:41 jdhcpd_pool_find: cfg 7d8000, pool_name 8caf10, DefaultPool
Aug 2 04:40:41 jdhcpd_pool_find: Pool DefaultPool found 0x7e0800 w/ cfg container 0x7d8000
Aug 2 04:41:14 ifd-event ge-0/0/15, oper change, state up, dev_index 149
Aug 2 04:42:45 Client 74-3e-2b-M-A-C stale timer expired for client-type 1
Aug 2 04:42:45 jdhcpd_auth_release: auth logout initiated for session 12 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE: flags1:0x20000; flags2:0x10
Aug 2 04:42:45 jdhcpd_auth_release_common: Release authd (request user logout): updating SDB with client session state SDB_SESSION_STATE_TERMINATING
Aug 2 04:42:45 jdhcpd_session_db_client_session_state_set: setting session state 3
Aug 2 04:42:45 jdhcpd_auth_release_common: ISSU logout for client session id 12, decrement global in-flight logins (count is 0)
Aug 2 04:42:45 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:42:45 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:42:45 Added client w/ session_id 12 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:42:45 jdhcpd_auth_release_common: auth logout requested for session 12 in state LOCAL_SERVER_STATE_WAIT_AUTH_REQ_RELEASE: flags1:0; flags2:0x10
Aug 2 04:42:45 jdhcpd_user_logout_rply_proc: Got reply for user_logout, reply rqst_id = 65550 (session Id 12)
Aug 2 04:42:45 Get SDB STATE for session Id 12
Aug 2 04:42:45 Got SDB SESSION STATE 3 for client session Id 12
Aug 2 04:42:45 jdhcpd_user_logout_rply_proc: Got authd reply for user_logout in SDB state TERMINATING, for client x.y.z.251, client session Id 12
Aug 2 04:42:45 Request to remove client w. session_id 12 in state 4 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:42:45 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:42:45 In state LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ: starting updating SDB with client session state SDB_SESSION_STATE_TERMINATED
Aug 2 04:42:45 In client state LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ: updating SDB with client session state SDB_SESSION_STATE_TERMINATED
Aug 2 04:42:45 jdhcpd_session_db_client_session_state_set: setting session state 4
Aug 2 04:42:45 Set to LOCAL_SERVER_STATE_WAIT_SDB_TERMINATED_MIRROR_REQ, SDB ACK will notify us for LOCAL-SERVER client session Id 12
Aug 2 04:42:46 Successful SDB Mirrored Ack: returned code SDB_SUCCESS for session id 12
Aug 2 04:42:46 LOCAL-SERVER: SDB mirroring ACK received in client state 26
Aug 2 04:42:46 jdhcpd_auth_release_terminated: auth terminate initiated for session 12: flags1:0; flags2:0x10
Aug 2 04:42:46 Before adding to teardown list, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:42:46 LIST IS EMPTY, jdhcpd_inst.authd_restart_teardown_count 0
Aug 2 04:42:46 Added client w/ session_id 12 in state LOCAL_SERVER_STATE_WAIT_CM_DELETE, to authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:42:46 jdhcpd_auth_release_terminated_common: auth terminate request for session 12: flags1:0; flags2:0x10
Aug 2 04:42:46 jdhcpd_user_terminated_rply_proc: Got user-session terminated REPLY from authd- reqId 65550, for client session Id 12
Aug 2 04:42:46 Request to remove client w. session_id 12 in state 5 from authd_restart_teardown list, count authd_restart_teardown_count 1
Aug 2 04:42:46 Removed LAST client from authd_restart teardown list, zero out COUNT authd_restart_teardown_count
Aug 2 04:42:46 ATTEMPT TO DELETE libstats; session_id = 12
Aug 2 04:42:46 libstats delete stats: passed session_id 12
Aug 2 04:42:46 Deletion of baseline stats for session id 12 succeeded (client index 65550)
08-05-2019 08:58 AM
08-05-2019 10:16 PM
