09-07-2023 02:31 AM
Hello all,
I have got some APs (R310, T301) with software version 3.2.x but the controller has version 3.6.x (which doesn't support older versions than 3.4).
So i am not able to upgrade the APs from the controller.
Is it possible to do it manually?
Do you know if there is any workaround to solve the problem?
Thank you
09-07-2023 02:56 AM - edited 09-07-2023 07:59 AM
Hi @Net2023 ,
Thank you for reaching Ruckus Technical Support via FORUM.
Please could you upgrade both APs to it latest solo firmware and try adding the SZ managed network.
Solo firmware can be downloaded from https://support.ruckuswireless.com, click on downloads, select respective product for its firmwares.
Vasanth Edward
