Thanks Andrea
How many clients are connected to this wireless LAN? Answer 70 to 95 users
Are you using VLANs? Yes there are VLANs at the network switch, VLAN 10, 30, 40. But we deployed this WLAn using a new GE POE switch on VLAN 1. This means that we added the new switch to the access port of the network switch. We did not bother about the access VLAN untagged on the port and the controler worked fine at this setup.
What brand/model switches are you using? It is Edgecore 4210 10p
On the VLAN, when we added the new switch, we tried to configure the uplink port as Trunk for VLAN 10, 30 and 40, and since the customer designated VLAN 30 for wiFi, the 8-LAN or downlink ports were configured as access to VLAN 30, but once we configured the access VLAN 30 on the 8-LAN ports connecting ZD and APs, the APs lost heart beat and controller failed to control APs.
We tried changing the ZD1106 and AP VLAN from 1 to 30 but this did not work, we even lost web login access to the ZD1106. APs also did not sync with controller, please what do you suggest here?
I am very grateful for your feedback
Regards
