Need to hand out isolated DHCP on an H510 port
joshua_lee1
I have a healthcare client who has a faulty wireless bridge on their mobile ultrasound machine. I had an idea to replace that device with an H510 and mesh it to the wireless network. However, they need to hand out DHCP to the ultrasound machine computer that will be plugged in to one of the H510 wired ports. That scope should only exist on that port of that AP and nowhere else. Is there a way to enable DHCP for an AP on the wired port? I know I can enable DHCP pools on specific APs, but does that get handed out to the wired ports as well or just wireless? Thoughts? By the way, this is managed by a cluster of SZ-124's running 5.1.0 firmware.
1 REPLY 1
hemant_bhatnaga
Hi Joshua,
Yes this is possible by making the H510 AP ( and other APs)  ethernet port convert to default wan to default LAN option or by changing the topology from multiple APs to hierarchical AP option.
Could you please provide details on what is the DHCP /NAT option selected on the GUI (Multiple AP or Hierarchical AP)?
Hemant
Type a product name
