Over All Problem: We have an AP that is causing us issues. Randomly, when you connect to it, one of 3 things will happen...
1. Connects, no problems
2. No IP address, but you're able to connect to the AP
3. The user is told that their password is incorrect and they need to input the correct password
Scenario:
- We are utilizing a Zone Director 3025 appliance (Ver: 10.0.1.0, UpTime: 24d)
- We have approx 75 AP's (r7982, r700, r510...All restarted within the past 24 days)
- We are utilizing PSK's
- We are utilizing dynamic vlans where users are placed on one of 5 vlans based upon conditions setup in RADIUS
Troubleshooting
- I have been unable to narrow down the AP(s) causing the issue
- The issue doesn't happen all the time, it seems to happen randomly to random devices at random intervals of the day.
- All switch ports have been verified
Things we know
- There isn't a known DHCP issue. If the user wanders to a different AP, then they will receive a valid IP address.
- The user's PSK is good. If the user wanders to another AP, it connects to the AP & network with no issues
Requested Assistance:
I am looking at AP's that are around the affected area in an attempt to narrow down what may be causing this. We had an issue with a device and I captured the log from one of the AP's the user connected to, but I can't find any information on interpreting the AP log data. Any help interpreting the logs below would be greatly appreciated!! Thanks!!
Kevin
Oct 17 14:03:04 EW-A-1171-O local2.err syslog: lwapp_proc_add_mobile_apend_dvc_type: send device type to zd, rc 26, station 5c:f7:e6:bb:41:5e
Oct 17 14:03:04 EW-A-1171-O local2.err syslog: lwapp_update_role_based_access_pcy_me: error: attached role based policy_id :0, policy6_id :0 to station ,rc = 255 me_type=6 5c:f7:e6:bb:41:5e
Oct 17 14:03:04 EW-A-1171-O user.info kernel: net80211_tac_cfg_sta_set_param(): set station 5c:f7:e6:bb:41:5e vlan_id = 600
Oct 17 14:03:28 EW-A-1171-O daemon.warn Eved: STA-DISASSOC-REASON [ieee80211_input(),2076,received IEEE80211_FC0_SUBTYPE_DISASSOC] 5c:f7:e6:bb:41:5e rx_rssi=15,ack_rssi=0,reason=8,freq=2412,chan=1,rx pkt,byte;tx pkt,byte=(524,65243,686,557786)
Oct 17 14:03:38 EW-A-1171-O user.info kernel: net80211_tac_cfg_sta_set_param(): set station 5c:f7:e6:bb:41:5e vlan_id = 600
Oct 17 14:04:56 EW-A-1171-O local2.err syslog: lwapp_proc_add_mobile_apend_dvc_type: send device type to zd, rc 26, station 5c:f7:e6:bb:41:5e
Oct 17 14:04:56 EW-A-1171-O local2.err syslog: lwapp_update_role_based_access_pcy_me: error: attached role based policy_id :0, policy6_id :0 to station ,rc = 255 me_type=6 5c:f7:e6:bb:41:5e
Oct 17 14:04:56 EW-A-1171-O user.info kernel: net80211_tac_cfg_sta_set_param(): set station 5c:f7:e6:bb:41:5e vlan_id = 600
Oct 17 14:05:03 EW-A-1171-O daemon.warn Eved: MLME-REPLAYFAILURE.indication(wlan0 AES-CCM keyid=101 unicast RA:addr=e0:10:7f:3b:63:38 TA:addr=5c:f7:e6:bb:41:5e) (pkt-rsc:54 k->rsc[1]:56
