Is there a way to script a reboot on the R700
charlie_wallace
Is there a way to script a reboot on the R700?s like a cronjob that resets them at a given time, or every 24 hours, i find the double in performance after a reboot. I have 8 R700's on a zone director 3000 and one standalone (elsewhere)
thanks
31 REPLIES 31
Thank you for the script I usually use it but need reboot by schedule for that reason I ask the usage of the script above. Still do not know how to integrate the script to the zonedirector. I hope get answer soon 🙂
You wouldn't necessarily integrate the script into ZoneDirector, itself. You would have to write the script (or have someone else write it on your behalf), then you would use a Scheduling Service, like Cron/CronTab in Unix/Linux and Task Manager in Windows to Automatically run the Script on Schedule, etc.
Thank you very much, I will try to do 🙂
bill_burns_6069
Contributor III
Here is the scheduled AP reboot script.
https://github.com/bot779/ruckusconf/blob/master/rebootat3am
It requires the latest version of the ruckusconf script.
https://github.com/bot779/ruckusconf/blob/master/ruckusconf
"rebootat3am" should prompt you for your ruckus password, test the password by logging into your controller, wait 'till 3:30am the next day and then run the "reboot" command.
WARNING:
It is intended to reboot all of the APs connected to your controller.
This will disrupt your wifi connectivity.
Test it at a non-critical time.
In order for it to work, you will have to change the hard-coded IP address (at the end of the script) to the IP of your controller.
If you want the reboot to be scheduled at a different time, that will require editing the script.
You will need to leave this script running in a window 'till the scheduled time.
If you have any questions, let me know.
Thanks for sharing Bill.
