Is it possible to force use of indoor channels in an Outdoor AP ?
nuno_pimentel
Contributor
Hello, it's possible somehow to force the usage of indoor channels on a outdoor AP, like T300, because sometimes i use them indoor in some venues, and it was good to have also that channels available.
regards
4 REPLIES 4
demetris_demetr
In the AP settings or on the AP Group settings, you have the option to select the pool of channels you can use. This setting is available on ZD but don't know if it is available on standalone. What do you use?
nuno_pimentel
Contributor
I use ZD, In group i see that, but it's considers that a group can contain indoor and outdoor AP's, if i try to override configuration of a group on a single AP on the outdoor AP's i don't have the option to use the indoor channels.
demetris_demetr
What happenes if you go on Configure->System and on Country Code section you tick the Channel Mode Allow indoor channels (allows ZoneFlex Outdoor APs to use channels regulated as indoor use-only)?
nuno_pimentel
Contributor
thanks 🙂
