Is Zoneflex 114.0.0.0.1294 compatable with SmartZone when onboarding AP's. Regarding R610's
Customer is looking to change out to a SmartZone appliance. Preemptive question if firmware needs to be changed.
Zoneflex 114.0.0.0.1294 compatible with SmartZone when onboarding AP's.
2 REPLIES 2
Hi Mark,
The answer is yes, firmware 114.x is indeed designed to support SZ platform.
If the SZ is running latest 5.2.x firmware make sure to set IPv4 only mode from AP CLI to prevent running into AP onboarding issues.
rkscli: set ipmode wan ipv4
OK
rkscli:
Parikshith
syamantakomer
Community Admin
Community Admin
Hi Mark,
Yes, it is compatible!
All you need to do is, discovery the controller using DHCP or DNS, or you can manually point the AP to the controller.
Command for AP CLI is:
set scg ip xxx.xxx.xxx.xxx (here x.x.x.x is the SZ controller's control IP address)
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
