How to make ap router mode with cli?
hyosang_choi
Valued Contributor
Hi.
We want to make ap router mode using only cli.
We configured everything setting, but don't found how to configure local-subnet at wlanX.
How does it configure?
We have completed making localsubnet and ssid.
(ex. set subnet local-subnet1 enable ipaddr 192.168.100.1 mask 255.255.255.0 untag 100
set subnet local-subnet1 dhcps enable starting-ipaddr 192.168.100.11 user-number 240)
Only We don't find just configuration.
I tried "set interface wlan0 forward local-subnet type access untag 100 vlans 100".
But it faild.
Image_ images_messages_5f91c3e3135b77e2478caeb3_995deb5ea64b67bfdb84089a51948945_RackMultipart20160624126272190-9ef03e16-fb09-4ce7-95c8-474cad9b1a73-359844086.png1466750446
Plz let me know.
5 REPLIES 5
Esteemed Contributor II
Hi Jeronimo,
   Ruckus Product Line Management has "generally" not supported ZD/SZ or AP CLI
and would attempt to incorporate any CLI-only available settings into WebUI.  If you
have a strong business case need to configure Solo AP mode APs via CLI and can't
configure these settings, please contact your Ruckus SE or our Tech Support team to
ask for a Field Request (FR) so the PLMs can consider it?  This may be a reasonable
request.  Thanks and best regards.
stephen_hall_60
Contributor
same issue here.  we have figured out every part except this one option (how to set wlanX to use "local Subnet X")  .   and just like OP we had to reverse engineer all of this as ruckus offers no documentation on the cli/ssh.
Can you all answer if this is even possible?  (or will we need to use webgui for ~ 300 aps , just to set this one single option).
tks
Hi Stephen.
I had finally figured out a command you want and already applied it in site long ago.
That's it.
-> set rpmkey ifs/wlan0/subnet-idx 1
I have attached whole commands below to refer.
----------------------whole command---------------------
set subnet local-subnet1 enable ipaddr 192.168.40.1 mask 255.255.255.0 untag 40
set subnet local-subnet1 dhcps enable starting-ipaddr 192.168.40.11 user-number 200
set dhcps leasetime 3600
set interface wlan0 forward local-subnet type access untag 40 vlans 40
-> idx numbers are from 1 to 4.
-> that is , local-subnet 1 is 1 and local-subnet 3 is 3.
-> wlanX is number of wlan(ex. wlan0 ~ wlan7 are for 2.4Ghz and wlan8 ~ wlan15 are for 5Ghz.
If this reply has problem for a security, forum admin can delete.
Bye.
thanks alot for this answer!  very helpful
