08-29-2023 04:46 AM
I have 3 R510 Access points, I have set 1 AP as Master which is on second floor, the remaining 2 APs are member APs, I want to change Master AP from 2nd floor to the one which is in my Living room, how can I do that?
08-29-2023 10:01 AM
08-29-2023 10:01 AM
08-29-2023 10:11 AM
Thanks Ayush for the information, can you please mention the web address or url link so that I can change the setting using a computer. So far I have set up everything using mobile app, I don't know the web address to log into my account and change the settings online.
08-29-2023 07:46 PM
Hi @maynk
To access the Master web, you can use the below URL of either AP's IP address or FQDN
https://ipaddress
https://unleashed.ruckuswireless.com
